Re: spun bearing
Posted by rankrank1 on June 23, 2012 at 10:28:19 from (69.171.171.49):
In Reply to: spun bearing posted by blunted on June 23, 2012 at 08:19:09:
Another trick that I have used is to take a center punch and make divots where the bearing presses in. The divots will tightened up the tolerances some - try to make several divots and keep them somewhat evenly spaced. I would also use some of that bearing locktite liquid product mentioned in other posts as well since its inside a transmission and probably not real easy to get to again so any insurance that you can add is beneficial in the long run.
