Posted by El Toro on June 23, 2012 at 14:41:02 from (108.3.225.57):
In Reply to: Super A to 123 motor posted by Charllie in MO on June 23, 2012 at 13:10:22:
You buy the C123 sleeve kit and it can be installed in your Super A block without any machining. You need to measure the length of old sleeves. If they measure 6-7/8" in length you can only install the C123 kit.
Some of the Super A's came with C123 engines and have the 354898R1 engine block. Those sleeves are 7-1/16" in length and you can install an oversize kit to give you 133cid. No machining is needed to install them. You also need to clean that block area where the old sleeve seals are installed. Buff off any rust in that area and vacuum any rust scale in the block. Coat the new sleeves with a light coating of dawn so they slide thru the new seals easily. Hal
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
