Re: Crankshaft preservation
Posted by Janichoson on June 23, 2012 at 17:16:08 from (96.24.99.126):
In Reply to: Crankshaft preservation posted by IAtractorKid on June 23, 2012 at 16:34:13:
LPS corporation makes a spray on corrosion inhibitor that is (when dry) similar to cosmoline. It is not thick (as in 1/16") it is more like .005" but it stays waxy and if the part is left undisturbed, prevents rust! I would do that to it, then seal it in a vacuum bagger wrap. Very dry, and protected. If you intended to move it or store it where things could bash around, a quad thick cardboard tube would suffice. Jim
