Re: farmall c starting
Posted by MMZAck on June 23, 2012 at 17:30:13 from (24.20.195.226):
In Reply to: farmall c starting posted by scottbarbee on June 23, 2012 at 17:03:58:
You mention you are using 2 gauge battery cables, which are typically meant for 12V systems. Six volt systems need bigger battery cables to work properly. You should use 2/0 cable and it will more than likely cure the problem.
Zack
