Re: Bought a 52 SC with a mounted plow today
Posted by Dean Olson on June 23, 2012 at 17:30:34 from (98.196.66.64):
In Reply to: Bought a 52 SC with a mounted plow today posted by Zachary Hoyt on June 23, 2012 at 16:19:54:
Looks like Plow Chief bottoms that are pretty worn out. If your going to part out that plow I'd like to have that pair of extensions that are bolted to the back of the moldboards. I have Zenith carb off of a SC that I would swap.
I have mounted planters,cultivators,busters, and WAS looking for a plow. BUT when I figured out what a PIA it is to change out mounted implements I went to fast hitch equipment. Much easier to change operations with fast hitch.
When I was looking I found a few mounted plows but never on the tractor and the mounting brackets where missing. I suspect the hardware to mount will be worth more that the plows to the right folks. I'd try to sell the whole plow locally 1st and if it doesn't sell then part it out and scrap the rest.
