Re: M's head at the machine shop, quick question
Posted by sgtbull on June 24, 2012 at 04:02:45 from (163.191.228.254):
In Reply to: M's head at the machine shop, quick question posted by BigTone on June 24, 2012 at 03:30:53:
Your machinist can best advise you on that.. without seeing the head, no one can tell you what it needs. Chances are, at the very least, it could use a lapping. If the guides are worn, or the valves/seats worn or damaged, then of course it should be done. If you want a smooth running, easy starting tractor, the valves MUST be in good shape. Now is the time to do it.
