Posted by CNKS on June 24, 2012 at 08:33:12 from (216.144.104.128):
In Reply to: SH hydraulic question posted by oregonfarmer on June 24, 2012 at 06:46:56:
Not likely. Engine driven pump with reservoir under gas tank or belly pump? Engine driven does not have a reservoir dip stick. I just reassembled the one under the gas tank, without looking at the diagram, I imagine the release in the belly pump is similar. That is not a particularly easy repair when reassembling. Lift the lever up and push, banging on it is making the problem worse as you have two metal parts contacting each other. You must have worn a groove in one of them, but I would think you would have the opposite problem, that is not holding. How long has this been going on -- the previous owner may have put a stiffer spring in the hole it fits into.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
