Posted by smalltimer on June 24, 2012 at 11:07:49 from (74.112.208.162):
Been looking for a mid to higher power 2wd tractor for field work. Most of the Internationals in the 5088 5288 5488 series I have looked at either say trans has updates or when you are sitting in the tractor with it idleing the gear shifter just drops between gears grinding and a loud thumping coming for the rear end. Where the trans and rear ends a common problem on those models? Have looked at 86 series and I'm almost favoring those models (1586 1486) over the 5X88 series.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
