Re: Transmission to Clutch Shaft Removal - Super M
Posted by gab on June 24, 2012 at 15:05:44 from (50.103.8.147):
In Reply to: Re: Transmission to Clutch Shaft Removal - Super M posted by dpoc on June 24, 2012 at 14:15:19:
Yes to the 4 bolts but you have to remove the clutch release lever/shaft and the 2 bolts out of the through out brg carrier, remove the pressure plate bolts and then you can tip the clutch shaft to the side and out
