H Water Pump Hubs
Posted by Tom A. on September 29, 2000 at 21:16:28 from (208.241.20.10):
Red!
Thought it only fair to admit you were right about that pin, but I've received a good education. Come to find out there are at least three water pump hubs for application to the "H". One has no generator pulley, the other two do and both have pins, BUT, one pin cannot be seen because of a separate generator pulley obstructing its location, but the other is made as one single casting consisting of the generator pulley and the fixed flange for the pump pulley. Naturally, the one style I had was the one having the separate pieces. Once I pressed off both pieces, shearing off the pin, I immediately discovered the solution to getting them off.
Tom a.
Post A Followup
: Re: H Water Pump Hubs
