Posted by wayne in mn on June 24, 2012 at 18:29:16 from (24.179.181.245):
In Reply to: Farmall Brake Drum posted by TMonton on June 24, 2012 at 18:21:44:
Larger hole had the nut welded in with the jam nut & adjusting screw. The screw supports the bottom of the brake band so the brake doesn't drag. Install the brake band, adjust the free play, apply the brake fully & lock in place. Loosen the jam nut, tighten the screw then back off 1/2 turn and lock the jam nut. Small hole is for drainage of liquid.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
