Posted by pete 23 on June 24, 2012 at 19:28:27 from (74.32.238.2):
In Reply to: SH hydraulic question posted by oregonfarmer on June 24, 2012 at 06:46:56:
Try the other outlet. If you look at the parts diagram of the Super H hydraulic lift all, regardless of which one you have with belly pump or live pump, you will notice two different styles of check valves holding the load up. The one they call a differential check valve has a much smaller ball and therefore when holding heavy loads it is much easier and smoother too release to lower the load. If you are using two hoses, one on each side of what ever your are holding, you will have to T the two together to use the single outlet. I have over the years installed that style check valve to overcome just that problem you are having. If your H should happen to not have that small ball set up you can install it but you have to make sure the pin operating the ball is correct length so as to hold the load up when lever is in neutral position.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
