Re: Load 16 tons, what do ya get, a dead 450 and deeper i...
Posted by Bob M on June 24, 2012 at 19:38:27 from (69.207.87.163):
In Reply to: Load 16 tons, what do ya get, a dead 450 and deeper in debt posted by P and R Pete on June 24, 2012 at 18:51:36:
Your wiring has a BUNCH of issues!
If it were mine I'd remove every last inch of the old wiring and the battery cables and replace with new. Anything less is only sticking a bandaid the problem. (If you're lucky it will only soon quit on you again; if you're less lucky your tractor will go up in flames!)
A reproduction wiring harness set + new battery cables will run $250 - 300. Or you can make your own for about a third of that. Either way it will be money well spent(!)
