Re: Farmall front rim question ????
Posted by Crazy Horse on June 25, 2012 at 08:31:18 from (108.173.38.154):
In Reply to: Re: Farmall front rim question ???? posted by Andrew Z on June 25, 2012 at 08:08:04:
So the "loop hub" you mentioned is for the rim with the welded on tabs right? I was wondering about trying to cut or disc cut the tabs off, might be messy but this is not a showpiece tractor, the steel outer rim itself should likely be the same I'm guessing? I see it's the same as a rim I have here on a Massey 22 (full wheel type but the outer rim is identical)
