As Jim says, the valve timing is designed so the flow to the side of the valve that will be the "out" or pressure side is there before the "in" or return side opens. This prevents the cylinder from moving slightly in the wrong direction as the valve is moved. Because the "in" side is not open yet, or less open than the "out" side, the pressure is relieved over the relief valve, and they have tendancy to vibrate when barely opening or "cracking". Some relief valves can be pretty noisy or vibrate badly when cracking. You are lucky the hydraulic systems of that era are fairly low pressure.... a 5000 psi relief valve can have a really loud squeal :shock:
Part of the noise is induced by the gear teeth creating pulses, and in some systems they set up a resonant frequency that aggravates the noise. You may find the noise is worse at some engine RPMs than others.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
