Re: IH gaskets vs. Aftermarket gaskets
Posted by Andrew Z on June 26, 2012 at 10:05:06 from (64.148.21.144):
In Reply to: IH gaskets vs. Aftermarket gaskets posted by BigTone on June 26, 2012 at 08:44:52:
Not sure what there looking up but the last one i got from CNH was 55-60 bucks. Heck the Gasket for the MD-450D is 130... I would use the gasket off this site, they sell Victorinez (sp) gaskets, I have used feel pros as well but in my opinion they do not hold up as well to high compression as the victors do. I believe the CNH gasket is also made by victor same build, thickness etc. Either way you go you will be fine, copper coat and done. Most Most important make sure both surfaces are clean! lots of brake part cleaner / either / etc dry and clean!
Andrew
