Posted by RPM1941 on June 26, 2012 at 20:57:46 from (173.23.76.185):
In Reply to: 1066 Steering posted by Schoolman on June 26, 2012 at 15:42:55:
1066 has MCV & pump in ta/clutch center housing, its on the clutch pedal side ahead & down, has a lot of bolts to remove it. The rear frame has another pump but runs only the hitch & hyd couplers. Your tractor has problem in the MCV side (the front one). IH made a gasket/oring set to replace the common failure parts, IH 393877R92, hopefully this will cure the problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
