Re: joint at the front of trans on A.
Posted by gene bender on June 27, 2012 at 03:29:25 from (67.55.226.123):
In Reply to: joint at the front of trans on A. posted by blunted on June 26, 2012 at 20:21:05:
Take the plate and hammer the holes to get the ridges down if they are enlarged the tapered bolts should not have a lot of play any rubber and washer will work. I did get new washers from i-h. That shaft isnt a realy big deal as the bearing on the front of the tranny keeps the shaft in line and how often is the engine running 1400 rpms.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
