Posted by gene bender on June 27, 2012 at 03:39:21 from (67.55.226.123):
In Reply to: Super C electrical posted by Zachary Hoyt on June 26, 2012 at 19:19:50:
The wire is probably a way to ground the field to make the gen charge more. You mite need to service the gen. Tons of gens are running around with the field terminal grounded and have been running that way for yrs. The owners manual even says to do that.I would check the regulator to see if its original or a replacement which had a seperate terminal for the lite circut.Check the Delco # on the gen to make sure you have a correct regulator. You say top terminal means you do have a later C as first ones used a cut-out on the top then later they went to a reg mounted below the genand then also ghanged lite sw to three positions instead of 4 because the hi-charge was no longer needed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
