Re: Help understanding hydraulic system & with plan to s
Posted by sallystractor on June 27, 2012 at 12:04:33 from (66.243.210.130):
In Reply to: Help understanding hydraulic system & with plan to simpl posted by AES on June 27, 2012 at 11:36:04:
the hydraulic pump is at the distributor 0ne hose is the return ,one hose pressere .the pressure hose connects to the lever control valve marked IN ,also on the valve will be a port marked out this hose connects to the fliud resavior at the top ,at the bottom of the resivior should be a hose going to the return on the pump this completes the the circit the control valve may have a bypass valve that allows fluid to return to the resivor when pressure exceeds the set pressure install a pressure gauge in the system ,this way you know excat pressure from 500-3000 i run mine at 1500 psi
