Re: What is this item on Farmall M hydraulic system?
Posted by mkirsch on June 27, 2012 at 13:26:57 from (64.80.110.75):
In Reply to: What is this item on Farmall M hydraulic system? posted by AES on June 27, 2012 at 12:27:35:
Well, your control rod and lever for the belly pump is missing, so you must have an add-on live hydraulic system.
Trace it out. If that hose comes off the pump up by the distributor, goes past this "fancy elbow" and runs to the IN port on your hydraulic valve, it's a relief valve.
