Re: Super M rough runner
Posted by old on June 27, 2012 at 14:07:16 from (209.86.226.19):
In Reply to: Super M rough runner posted by Pat Connors on June 27, 2012 at 13:16:52:
Cold manifold it correct since it is part of how a carb works. As for ruffing running when hot most of the time that is a coil going south or valves that are getting to tight. Check the spark when it starts doing that. Should be a blue/white spark that will jump a 1/4 inch gap or more
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
