Re: F20 Crankshaft Removal in Stuck Engine
Posted by El Toro on June 27, 2012 at 14:19:12 from (108.3.148.85):
In Reply to: F20 Crankshaft Removal in Stuck Engine posted by doehmke on June 27, 2012 at 13:07:52:
If soaking the pistons with atf doesn't free them
I would move the tractor away from any building and remove anything flammable. Then pour kerosene or diesel fuel on top of a piston and set it on fire. Pull the head and oil pan off.
Only do one piston at a time and have the rod cap off. When the flame dies down use a piece of 2 X 2 oak and big hammer and see if the piston will move when placing that oak against the connecting rod and smacking the the oak. The sleeve may come out with the piston. Use a torch to free the piston. Hal
