Re: F20 Crankshaft Removal in Stuck Engine
Posted by Nebraska Kirk on June 27, 2012 at 20:32:15 from (207.91.4.159):
In Reply to: F20 Crankshaft Removal in Stuck Engine posted by doehmke on June 27, 2012 at 13:07:52:
I have removed stuck pistons & sleeves from F20, F30 and 10-20 engines and what works best for me is to press the pistons and sleeves together out the top of the block, then you can remove the crankshaft. Just put the piston & sleeve in a press and press the piston out of the sleeve.
