Re: Re: Farmall Cub 3 point hitch
Posted by Charles on September 30, 2000 at 17:02:51 from (24.93.12.83):
In Reply to: Re: Farmall Cub 3 point hitch posted by Paul on September 30, 2000 at 14:43:39:
You can get 3-point hitches from Central Tractor, or from Worksaver at worksaver.com. Be warned that the Cub for some unfathomable reason will not work with many common add-ons because its power-take-off turns in the opposite direction of most tractors, and at twice the speed. I'd hoped to use mine with a post hole digger, but that proved impossible. An expensive after-market add-on which changes the direction of the PTO and slows its speed is no longer available. ALSO be
aware that the draw bar weight is limited to 300 pounds (though you can add weight in front). So figure the weight of your implement and any additional weight it may bear, and act accordingly.
Post A Followup
: Re: Re: Re: Farmall Cub 3 point hitch
