Re: F20 Crankshaft Removal in Stuck Engine
Posted by NoNewParts on June 28, 2012 at 05:19:02 from (67.240.145.25):
In Reply to: F20 Crankshaft Removal in Stuck Engine posted by Centex Farmall on June 27, 2012 at 13:07:52:
If you're not in a hurry, keep trying to get it loose.
use a hone, wirebrush, whatever you have to get all the
rust out of the part of the sleeve you can see.
If you have been soaking it with no success, like Toro said,
set the holes on fire. Let it burn awhile and hopefully
you will start to see small bubbles coming up at the piston/sleeve junction.
of the tough one.
Put it out, give all piston tops a hardwood whack.
use your floorjack to put upward pressure with a hardwood post
on a crank throw going up. be gentle here
hardwood whack a piston top that is going down.
when you see the slightest movement, soak everything in oil
and keep it moving until free.
