Posted by BigTone on June 28, 2012 at 08:03:43 from (166.248.2.60):
In Reply to: Radiator flush? posted by Tuckermac on June 28, 2012 at 04:17:13:
Zach is right, I got a ton of help and you should be able to find it in the archives....There were two options, the first is you can buy a radiator flush from napa and flush the system. The other option (and what I did) was I drained all the fluid from the radiator and block as best as I could, I then filled the radiator with straight white vinegar (about 6 gallons for my M, not sure if its the same for an H). I started the tractor and got it up to temperature and then let it sit in the radiator/block for a day or so....it worked great, the fluid that came out was a muddy, rusty, color and it fixed my getting hot issue (you have to flush the system many times to get all the vinegar out though, i pulled the water jacket and put the garden hose right to it and got even more sludge out of the block/radiator)...what it also did was remove the rust from a couple blow outs in my head gasket...needless to say I had vinegar in the cylindars and oil...I removed the the head and found the blown head gasket, so if you use vinegar be ready to deal with possible issues with blockages/holes being opened up.
I would recommend you read the responses to my posts, tons of great info in there, the guys here really helped.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
