Re: How to check for a cracked block
Posted by oldiron29 on June 28, 2012 at 14:44:02 from (74.88.11.200):
In Reply to: How to check for a cracked block posted by BigTone on June 28, 2012 at 13:58:50:
Big, If the level dropped and stopped it is just balancing out. If you have water in the pan or leaking external than you have a leak or crack.
Sounds to like you had a damaged gasket installed.
oldiron29
