Re: 300 Flywheel surface questions
Posted by rhtx55 on June 28, 2012 at 18:31:17 from (207.119.53.237):
In Reply to: 300 Flywheel surface questions posted by Zachary Hoyt on June 28, 2012 at 18:20:53:
The engine flywheel definitely needs to be turned by a professional, it should clean up very nicely. I would take the T/A plates with you also, his machine will clean them up & get them perfectly flat also.
I have seen some pretty seriously heat cracked flywheels come off of Cat & Cummins engines turned and they come out perfect.
Get a local guy that does diesel engine flywheels and has quite a bit of experience.
I would first soak all the rusted parts in kerosene or diesel which ever you have handy, and then see what needs further cleaning or machining.
This post was edited by rhtx55 at 18:32:25 06/28/12.
