The 504 has two PS systems. Probably depends if it is rowcrop or utility. One system is hydrostatic with the valve at the end of the column, a flow divider, and a hydraulic relay that supplies directional power to the front axle.
The other system is a Charlynn Torque Generator directly below the steering wheel. Not sure where the power comes from. Perhaps a piggyback pump next to the main pump.
I put on a system on a non PS Farmall 504. I used a Charlynn TG right at the bolster. Power comes from a C, 100, 140 or similar hydraulic pump. That's a bolt-on installation below the distributer. 1/4" of the frame channel top flange has to disappear. The Charlynn required a bracket and a coupling. I suppose the Charlynn could go on any of the 4 (?) steering shafts. The closer to the bolster is the best arrangement when one considers the crappy U-joints and shaft bearings.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
