Re: 1947 Farmall A steering
Posted by gene bender on June 29, 2012 at 04:11:54 from (67.55.226.123):
In Reply to: 1947 Farmall A steering posted by Mark Slavens on June 29, 2012 at 02:47:40:
The tierods can be adjusted for play and if they are egged shaped a little work with a disc grinder they can be rounded again. The steering sector mite need some bushings,seals and a bearing. The output shaft also mite be loose. You realy need to start with the steering secteor first then work back to the tierods and bearings probably just need to be repacked and adjusted. Check the spindles to make sure the grease is getting to the bottom. Ive done a bunch and ended ip with good results.
