Posted by Janicholson on June 29, 2012 at 06:42:02 from (96.24.99.126):
In Reply to: SH compression posted by DeltaRed on June 29, 2012 at 04:29:08:
The issue is interesting in that there are variables that make our response valid -or not-. The first is that, the test cnditions must include: an open throttle, a good starting system that cranks the engine at 3 to 4 compression strokes per second, a leak free compression tester that is accurate (tested on a air source that is known pressure). If that is the case, and the engine was built with flat top pistons and a distillate head, I would say the readings are just a little low, but not much. If it was built as a gasoline SH (especially with domed pistons and or a big bore kit, it is at about 50% of normal. My take is that if it provides good power as you need to use it as you do, leave it alone. Running simi synthetic 10-40 oil, and a one step hotter plug can be helpful in reducing the foweling. Jim
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
