Re: cleaning out bad oil, Block Update
Posted by rustred on June 29, 2012 at 08:56:56 from (184.151.222.177):
In Reply to: Re: cleaning out bad oil, Block Update posted by rustcollector on June 29, 2012 at 07:44:58:
bad bad idea. hard on brgs. especially the rod brgs, as diesel or gas is a poor lubricant.at least have 1/3 of oil with that diesel. dont forget engine wear is on startup , when brgs are not under oil pressure ! so why would you be spinning the crank with no brg. lube? no one even thinks of that.
