Posted by Janicholson on June 29, 2012 at 14:20:54 from (96.24.99.126):
In Reply to: Re: SMD running posted by ihjason on June 29, 2012 at 13:59:50:
I agree it is easy to fix, and does not need to be rebuilt or spread out on the bench. Removing the side cover should let you see the plunger and if it does not move when cranking, it needs to. I have used a tiny amount of carb spray, and a rag to keep it where it belongs to free mine after 4 years of not running. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
