Re: F20 Crankshaft Removal in Stuck Engine
Posted by Nebraska Kirk on June 29, 2012 at 16:00:49 from (207.91.4.159):
In Reply to: F20 Crankshaft Removal in Stuck Engine posted by JRSutton on June 27, 2012 at 13:07:52:
I made a simple frame that will hold the engine block upside down in my press without having to remove the head studs. I also turned a puck on my lathe that fits on the bottom of the sleeve, I cut a notch out of it to clear the connecting rod.
third party image
third party image
This is a tool I made for pulling F20 crankshaft out. It will also work on F30 crankshafts.
third party image[/img]
