Re: ammeter
Posted by Janicholson on June 29, 2012 at 20:23:06 from (96.24.99.126):
In Reply to: ammeter posted by GordoSD on June 29, 2012 at 16:55:33:
If you disconnect the Bat wire from the Regulator, that indication of charge might go away. Someone probably put the battery in negative ground, then polarized the generator (or not) and now the contacts are stuck, making the generator heat, and the battery to discharge. If you were towing it 15 miles or more, the air flowing around the gen probably kept the smoke inside. If my theory is correct, resetting the ground, and unsticking the VR cutout contacts might make it go just fine. Before starting it repolarize by jumping from Bat to Arm for one second. Jim
