Re: Model A cooling fan
Posted by Jim Becker on June 29, 2012 at 21:21:17 from (173.74.120.222):
In Reply to: Model A cooling fan posted by D Slater on June 29, 2012 at 21:04:49:
Quoting Removed, click Modern View to seeThat's your answer, right there. Read the Owner's Manual on how to oil it. Essentially, you squirt some oil in then turn the opening down to drain off the excess.
There are 2 different styles of those hubs, so I can't tell you exactly what the inside looks like. In any case, I don't know where your bits of cork came from, maybe remains of a gasket. There should be a gasket between the fan blades and the hub, one way or another. Look at the parts catalog drawings to see how it should fit together. There is no seal needed on the shaft.
