Re: F 12 head gasket
Posted by Dave Allgire on June 30, 2012 at 06:17:21 from (24.217.34.3):
In Reply to: F 12 head gasket posted by phillip womble on June 29, 2012 at 16:22:25:
I"ve torqued mine to 90 lb/ft. Start out with 20-30 lb/ft on a torque wrench and in the middle of the head and work out to the ends of the head. Increase the torque setting by 20-30 lbs until you reach 90 lb/ft. I have not had any leaks on any of my tractors using this method. You can set the valves at .013" cold and then after the engine has reached operating temperature, recheck/set them again. Or set them at .015" cold and after the engine has reached operating temperature, recheck/set them for .013". The end result should be a setting of .013" hot. I would also recheck the torque on the head bolts, too.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
