Re: ammeter
Posted by CNKS on June 30, 2012 at 13:41:06 from (216.144.104.128):
In Reply to: Re: ammeter posted by GordoSD on June 29, 2012 at 18:27:36:
I bought one from Steel Wheel Ranch last summer for $2500, repairable sheet metal, no large dents, good TA, 12 volt, runs ok, power adjust wheels with lousy tires and bad rims. Some hydraulic leaks. Price is maybe $500 too high, but this tractor will have an engine overhaul, transmission work if needed (appears to be ok), complete disassembly, all seals and gaskets replaced, bearings where needed and base clear paint. I don't care for the power adjust wheels and will probably try to talk Mike into trading for wheels and double bevel rims. Mike is a little high on his pricing, but I have bought 3 tractors from him because I know what I am getting, with relatively few defects.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
