Re: Narrow front wobble fix??
Posted by Tom R S on June 30, 2012 at 20:21:01 from (75.207.9.120):
In Reply to: Narrow front wobble fix?? posted by lbg57 on June 30, 2012 at 18:57:31:
We just fixed this problem on a 37 WC Allis.
We found the lower bearing was shot in the pedestal, the wheel bearings were worn in both wheels, and the worm gear was loose on its shaft.
I tightened up the worm gear by putting in a larger taperred pin, replaced all the wheel bearings, replaced the lower ped bearing and seals. I also made sure the bearings fit tight by punching the spindles before re-assebling with the new bearings
We can now drive the tractor at full speed in 4th gear with very little wobble.
I"ve never seen a taperred bearing so beat up as this one was from the bottom of the ped.
