Re: Identify this Farmall C
Posted by willie in mn on June 30, 2012 at 23:58:55 from (67.142.168.26):
In Reply to: Identify this Farmall C posted by Jim R on June 30, 2012 at 21:54:24:
Jim
Those numbers with a letter R & a number at the end are part numbers.
After the "2 26" you mention should be a letter. That would be the casting date. J=1940, T=1950. Count up or down the alphabet from there to get the date the block was cast. In your case Feb 26.
There will be a similar number set on large castings such as trans & rear axle.
IIRC, Both U & V were used in 51.
HTH
Willie
