Re: Narrow front wobble fix??
Posted by mkirsch on July 01, 2012 at 04:40:56 from (67.253.161.186):
In Reply to: Narrow front wobble fix?? posted by lbg57 on June 30, 2012 at 18:57:31:
You can get rid of a lot of the wobble without replacing the gears.
Check your U-joints. Easily replaced for a few $$.
Replace the bushings on the vertical shaft.
On mine the sector gear was loose on the shaft. I used an empty pepsi can to make a shim.
