Super M crankshaft timing
Posted by Mark Alayne on July 01, 2012 at 07:38:25 from (97.73.64.142):
I need some help please! I was mowing with my Super M the other day. I noticed a knocking noise and my tractor quit running immediately. Tried to restart it and I noticed the exhaust pipe "flap" wasn't moving. It wouldn't start. After further investigation, I found no compression in cylinders 2 and 4. Cylinder 1 had good compression and 3 had about 30 lbs. All pistons are moving up and down. I have compression at the exhaust pipe. Tried to start after resetting points and distributor timing as this has been an issue before and I hear a knock. I am guessing there is some issue with valve timing. Any help would be greatly appreciated. Thank you in advance for any and all advice.
