Re: pinion bear ing removal ??
Posted by The tractor vet on July 01, 2012 at 07:50:06 from (76.212.225.132):
In Reply to: Re: pinion bear ing removal ?? posted by sallystractor on July 01, 2012 at 07:09:13:
Before i had all the fancy tools to work with i would use a chisel that i had ground to get the bearing moving and kept going bigger . Now as to HOW to keep from knocking the bottom roller out when going back together , A heavy rubber band wrapped around the bearing to hold them tight and proper alignment and a couple of homemade dowel bolts and being gentle .
