First with the engine off take the pin out of the clevis going to the carb.Now open the throttle then see if holding the rod going to the carb open the pin will go back in if not then adjust the clevis.If that doesent solve the problem the gov should be removed and the bearing on the shaft mite need to be replaced. The bearing has three pieces a washer on each side of the bearing. Then theres a spring that mite be broke. that then should solve your problem if not remove the carb to see if the input lever has slipped loose getting the butterfly all out of whack.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
