Re: seating tire bead
Posted by rustred on July 01, 2012 at 21:38:31 from (70.28.245.114):
In Reply to: Re: seating tire bead posted by Janicholson on July 01, 2012 at 20:23:43:
i will also add , inflate without the valve stem core then once seated you install the core. this allows the air to go in faster and get a better seat. what are you lubing with? there is a thick goo that tire shops use for lube. looks just like grease. only time i have seen a problem seating tires is when no lube was used.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
