Re: Super A Battery Dead
Posted by Bob M on July 02, 2012 at 10:02:45 from (69.207.87.163):
In Reply to: Re: Super A Battery Dead posted by John Franklin on July 02, 2012 at 08:23:14:
John - That sounds like a bad battery (a good battery at rest will show 6.6 volts).
Another test: Stick your voltmeter across the battery terminals and watch while you hit the starter. If the voltage drops to near 0, the battery is no good.
Note: Even a new battery can be ruined by running it down fully flat. So even with another new battery you may still have have a problem (stuck relay in the voltage regulator) that needs attention.
