Posted by Janicholson on July 02, 2012 at 10:15:27 from (96.24.99.126):
In Reply to: Super A Battery Dead posted by John Franklin on July 02, 2012 at 06:30:25:
A new battery will often start and run a small tractor for a month. Especially if it is not used very much. If it charges when running (on the amp meter) then as discussed, the cutout points in the regulator may have stuck closed. Disconnect the battery while charging it (at the negative terminal post, assuming it is positive ground as from the factory) to isolate it from possible drains. It should be charging above 7 volts, but less than 8 volts. measured across the posts. When charged, with the lights off ,battery still disconnected, and ignition button pushed in, measure across from the negative post to the negative terminal for voltage, If you get less than one tenth volt, or nothing, it has no drain. If you get battery volts 6+, there is a short in the system possibly the cutout contacts. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
