Re: Super A Battery Dead
Posted by gene bender on July 02, 2012 at 13:20:38 from (67.55.226.123):
In Reply to: Re: Super A Battery Dead posted by John Franklin on July 02, 2012 at 10:45:07:
You can disconnect the ground cable and put a voltmeter in series if it reads batt voltage you do have something letting batt voltage thru. Could be the starter sw on top of the starter but ive never had any problems with that. Anothere check would be to disconnect the batt wire on the reg and again put a meter in series from that lead to the batt terminal that would show the reg is the culprit.
