Tony - Yes! This is what can happen if the hub has broken on the cam drive gear. It's not uncommon with this engine with a live hydraulic pump.
A couple quick tests:
- With the engine idling check the timing with a timing light. If the TDC notch on the pulley does not appear steady - ie. it moves randomly around - a busted cam gear is the likely culprit.
- Set the crankshaft at TDC, mark the rotor position on the distributor (should be under #1 or #4 nipple on the cap) then unbolt and slide back the hydraulic pump/distributor assembly. Now reach inside the timing gear case and grab top of the cam gear. If you can move it AT ALL with finger pressure the cam gear has failed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
